The Gerber File for InspectorBot’s Motor Drive board is now in the repository and under files in a ZIP format.
Below is an image of the board and the BOM for the board.
A project log for InspectorBot
An open source robot to inspect under vehicles, crawl spaces and any other dark dirty space you need to take a look at.
That is a lot of right angles and not-quite-straight lines. Have you considered cleaning this up to make it look better and be less problematic in manufacture? Also a ground fill would be nice.
Hi Radomir.
Thanks for the suggestions. This is an initial version. I
have one home print running and 3 prints coming for prototypes. It’s a tight timeline right now. After that I’ll
clean it up. :)
