stepZeroR2 designed and ordered
A project log for stepZero
A compact RaspberryPi Zero pHAT 3D printer and CNC controller
mo-badrMo Badr • 06/26/2017 at 21:41•0 Comments
I finally finished modifying stepZero and ordered the PCBs today, ETA 2 weeks. Hopefully I didn't make any mistakes -_-
The first revision had a couple of minor problems:
and one major problem:
I had initially intended to attempt to modify Marlin so that it passes the extruder commands to the daughter board over I2C (or even using the pins as SoftwareSerial). When that seemed like a bad idea, I thought I can have Marlin set and query the heater and motor direction using I2C, then switch one of the pins to a mode that would simply pass on the incoming steps signal to the step pin on the expansion board and the second pin to switch it back to I2C. After a second though, I decided that's probably not a good idea either.
Thus the modifications I made are as follows:
stepZeroExpR2
Aside from fixing a small problem with the stepper driver footprint being a bit too wide, stepZeroExp did not have any problematic issues. I had already broken out the UART pins in addition to the I2C pins in stepZeroExpR1, so I would have been able to use the new stepZeroR2 expPort, but I redesigned it to use the newer pinout for convenience. I also added a MOSFET to control a second fan, thus having one fan cooling the extruder itself while the other is cooling the print. Finally, I changed the stepper driver headers to two regular full rows (unlike on the main board) and moved it to the center of the board.
