Today I finished installing FL module.
First, I changed voltage regulator from MCP1702 to MCP1790, so that now the module can be powered from 24V.
Then I installed the module inside its case:
The last thing I had to do was securing the wires. I used 3D-printed wires holders and zipties:
Now the only thing left is testing the lights when it's dark outside :)
