Now I'm going forward next step which is trying to intercept communications between wireless modules and the base station they are connected. So for that I purchased a Wireless Development Board form NXP the USB-KW24D512 which has sniffing utility built in and can sniff Xbee packets by default. Also you can write your own wireless application for it and run it on its ARM M4 embedded processor.
Dimitris Andritsakis
