I've been working on the project little by little, but not enough to post on here. It's gotten cold, so range testing isn't a very tempting prospect at the moment.
I've retired the vocore and got it running on a RPI 1 B+, I was having some connection issues with the unsoldered pins stuck into the vocore's GPIO via throughholes, and I want to use it in some future projects, so I don't want to gunk it up with solder.
I've got some false positives coming in from the radios that can cause a desync issue, which I'm trying to track down. I'm not completely done with the project as is stands though, so check back every month or so and see if I've made any headway!
