Current Status
A project log for Seeing Space Table
A table to see what mechatronic systems are thinking.
minifig404minifig404 08/20/2014 at 05:090 Comments
The questions regarding the radios and database choice are still open. Regarding the radios, I can just try both and see which one works better. It is a little harder to do that with the database question...
Next step is to order a couple of radios, and start architecting the server-side portion. After that, I can design UI flows, and put together all the pieces. Once I have basic sensor logging and searching done, I can add the video feed, and video processing to identify movement.
For now, rovers are going to be the main focus. I'll add in tweaking for other robot types later.
Rich text editor
