How I connected and programmed the LCD to Arduino Uno R3:
As you can see from the picture above it can be a little messy to connect up the LCD module to the Arduino Uno board. I usually try to keep my wire colors coordinated so I know what are power, ground, and data but didn't have everything I needed this time around. Below is the circuit diagram which is easier to look at:
LCD Sketch
The LCD module that I used was a 20x4 which means 20 characters per row and 4 rows. To display a message on the LCD display you need to put the message into the LCD display registers then put instructions in the LCD instruction register. This can be a little complicated but the Arduino has a built-in library to handle the low level interaction for you. The key is to use the right setup with the LiquidCrystal() function as described below from the Arduino website:
Below is the Sketch for the Arduino Uno to send a message to the LCD:
//Date: 8/2/15
//Version: 1.0
//Comments:
//This sketch writes a message to a 20x4 character LCD display.
// LCD Pinout Connection:
// RS Pin: Connect to digital input 2.
// Enable Pin: Connect to digital input 3.
// D4 Pin: Connect to digital input pin 4.
// D5 Pin: Connect to digital input pin 5.
// D6 Pin: Connect to digital input pin 6.
// D7 Pin: Connect to digital input pin 7.
// R/W Pin: Connect to Ground so in write mode which is logic low "0".
// Vo Pin: Connect to the 10K pot that is connected between power and ground.
// Arduino LCD Display Library
#include
// Call the library with the right pin configuration
// In this sketch we are using: lcd(RS,EN,D4,D5,D6,D7) in 4 bit mode
LiquidCrystal lcd(2,3,4,5,6,7);
// The setup runs once when you press reset or power on the board
void setup() {
// Setup the LCD display column and row
// We are using a 20x4 display in this example
lcd.begin(20, 4);
// Main code for Arduino goes in the loop function to be run over and over again
void loop() {
lcd.setCursor(0, 0); // set the start of the message to be first column first row
lcd.print("Line 1"); // print a message to the LCD
lcd.setCursor(0, 1); // set the cursor to print beginning of second line
lcd.print("Line 2"); // print a message to the LCD
lcd.setCursor(0,2); // set the cursor to print beginning of third line
lcd.print("Line 3"); // print a message to the LCD
lcd.setCursor(0,3); // set the cursor to print beginning of fourth line
lcd.print("Line 4"); // print a message to the LCD
Timothy Coyle
