The evaluation kit has arrived! This next week I plan on generating an ECC key on the device & writing a simple program that will retrieve the public key from the device, issue authentication challenges, receive the responses from the device, & determine if valid. Once this is complete, the next step is to implement this back-and-forth over a Bluetooth connection.
Chris Finn
