Steel Rose #5
I do blacksmithing demos at a local ren faire; pounded this out for a friend.
0 followers
Started with bar-stock and a square rod; thinned out one side of the bar stock using a cross-peen and ball-peen hammer and coal forge. After the stock was thinned out petals were cut in with a wedge and the formed with the ball peen. These were then bent outward a bit at the ends and wrapped around the stem.
All done!
JPEG Image - 968.40 kB - 07/02/2017 at 02:10
Preview
Close up the curl I added to the end of the stem (other smith's ash tray in the background)
JPEG Image - 497.65 kB - 07/02/2017 at 02:10
Preview
