A sheet of foil would be stretched across a 3D printer bed as tight as possible. The 3d printer would print the board atop it. When the printing is done the board would be flipped over and placed on the bed again. The 3D printer then would print the mask, which could also work as a silkscreen after etching, and the board could be etched.
