I decided to 3D print a case for an Al-air cell. The diameter of the case is just large enough to hold a charcoal water filter disc. Ideally I would use a thinner disc, but the size that I am using happens to be available cheaply. The photos below show how the battery is put together. Note that the photos show two 12mm M3 bolts, but I ended up using 20mm bolts, not 12mm. The bendy wire shown in the photos is lead free solder with a tin content of 99.3%, chosen because it is unreactive. I used aluminium foil folded over four times and cut into a disc shape as the energy source. In the fourth step, 4 drops of saturated salt water solution are dropped onto the tissue paper.
![](https://cdn.hackaday.io/images/9447651515154818943.jpeg)
![](https://cdn.hackaday.io/images/4053201515154854354.jpeg)
![](https://cdn.hackaday.io/images/8536391515154905846.jpeg)
![](https://cdn.hackaday.io/images/4599641515154964958.jpeg)
![](https://cdn.hackaday.io/images/5341341515155001644.jpeg)
![](https://cdn.hackaday.io/images/3073171515155105247.jpeg)
![](https://cdn.hackaday.io/images/2836591515155164838.jpeg)
After it was assembled, the cell produced 12mW when powering a joule thief, as shown below:
![](https://cdn.hackaday.io/images/9004021515155362560.jpeg)
![](https://cdn.hackaday.io/images/9786571515155364661.jpeg)
![](https://cdn.hackaday.io/images/4304191515155369158.jpeg)
