Hacking castor wheels of plastic using rollerblade rubber wheels, to reduce shock's vibration, and changing bicycle wheel's bearing with a 12x20mm bearing, fitting perfectly on a normal wheelchair axle.
A project log for TooWheels - the opensource wheelchair
TooWheels is a completely DIY wheelchair designed to be made everywhere in the world! www.toowheels.org
