Hackaday.io Hackaday.io
Sign up Log in
Monitoring an Aquatic Ecosystem Using Raspberry Pi
Use sensors from Atlas Scientific to measure the water quality of a sealed aquarium.
chrisChris
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
0 comments
160 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2k
0
160
5
Team (1)
  • chrisChris
Join this project's team
hardware
ongoing project
2017HackadayPrize Sensors raspberry pi ecology water
This project was created on 07/11/2017 and last updated 9 years ago.
Description
I will use sensors from Atlas Scientific to measure the water quality of a sealed aquarium. The aquarium will consist of a nominally balanced ecosystem - shrimp, snails, plants, and other organic matter. The aquarium will be sealed to prevent exchange of air or other mass with the outside environment. With that constraint, the ecosystem can be monitored to see what effects the animals and plants have on the water. Changes in water quality may occur before changes in the rest of the ecosystem. If this happens, and these changes are repeatable across several closed aquariums, then there are clear implications for freshwater management. This project may also help improve the viability of closed ecosystems, including that of space colonies.
Files
Integrated all five sensors, including the voltage isolators for each of sensors that sensitive to electrical interference. Tested the read-outs using a slightly edited version of the sample code that Atlas Scientific provides. Next step is determining the best way to log photographs of the tank.
JPEG Image - 1.62 MB - 08/06/2017 at 01:32
Preview
Project Logs
Collapse
  • Uploaded rpi2.py to Github
    Chris • 07/13/2017 at 03:33 • 0 comments
    Uploaded rpi2.py to Github. Need to improve the file, so that it can pull data from all five sensors, and write the data to a .csv file.
    https://github.com/cnloyd/Raspberry-Pi-5-Sensors/blob/master/rpi2.py
    The project's "main" Github page:
View project log
Log In/Sign up to comment
Sign up with Github
OR
Saving water with your smart-phone
Project Owner Contributor
Project pH5.6 IoT Water Harvesting System
sagnik-bhattacharyaSagnik Bhattacharya
Hackaday Prize 2020
If our pollution adversely affects the environment, then, it's our responsibility to protect the environment, humans, plants, and animals
Aquarium Monitoring System - 3G/4G/IoT/AWS
guillermo-perez-guillenGuillermo Perez Guillen
Official Hackaday Prize Entry
This system decides how much water your plants need according to its sensors and internet weather stations and controls a pump to water them
Autonomous watering system
alvaroAlvaro
Supplyframe DesignLab: 2022 Hackada…
A self-watering and self nutrient feeding tomato hydroponics apparatus with live monitoring and environmental data analytics.
Advanced Hydroponic Garden of Eden - IoT
uncle-toby-and-aquamanUncle Toby and Aquaman
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Monitoring an Aquatic Ecosystem Using Raspberry Pi", please tell us the reason.
Send message
Remove Member
