Currently have only put the software together but hope to add the hardware and start testing soon.
The controller is able to run temperature profiles for mashing and run a constant temp. The Raspi will be wired into a relay that will turn the heating element on and off. Optionally a pump can be added to circulate the water in the mashtun if desired.
sven
EJ Boettcher
simon
Asep Bagja Priandana
