2017-07-24 (M) Pi0 Laser Tag PiTagErrUs
A project log for PiTagErrUs
Transform a piece of plumbing pipe into a rugged laser tag gun.
brian-mcevoyBrian McEvoy 08/17/2017 at 16:520 Comments
Three custom circuit boards were populated. On-hand components made it a fast process because time was not spent searching for the correct components.
Three circuit PCBs
Components like the three-position screw terminal and the twenty-four-position IC socket made it unnecessary to cut down existing components to go in their place. Before, long header strips had to be cut down to make a socket for the Arduino and two-position screw terminals had to be cut in half to make a third terminal.
Close-up of boards
