LEDs being affixed into their holes
Four forward arrays were completed. All the components, screws, lenses, and LEDs were attached. It should be noted that the holes drilled for the LED holders were 9/32" (7mm) which was two standard drill bit sizes up from the 1/4" (6mm) bits used previously.
Components and lenses mounted
Infrared sensors were glued to the front of the forward arrays with ordinary super glue then held in place with rubber bands while they dried.
Sensors glued in place
