Light rings with tinned terminals
Wires were soldered to each terminal with no regard to wire color. The color coding will be arranged when they are attached to the control board. Wires for power, ground and LED data were kept uniform because power and ground were tapped off the same terminals.
One soldered light ring
When all six rings were soldered, none of the wire coloring matched the other models. This should not be a problem but sheets will be printed and included with each tagger which explicitly defines the wire colors for each individual tagger.
Stack of six soldered LED rings
