Masking tape was applied to each side and the center lines were drawn. All the holes were marked at the same time and pilot holes were drilled at the same time. The large holes were drilled with a step drill bit. Marking and drilling multiple taggers only took a few additional minutes compared to the setup, execution and clean-up of a single tagger.
Cut and drilled pipes
Some of the holes were misplaced on the previous diagram. A new diagram was sketched and appears below. The old diagram put the PCB holder too close to the accessory rail riser. It should also be noted that drilling through masing tape can leave residue on the drill bit but the tape should be left on the bottom of the tagger so the handle and foregrip can be aligned properly. I failed to keep the tape on and it will make attaching these parts more difficult later.
Updated measurements for pipe
