Assortment of parts
All the wires were stripped at both ends. One end would be placed under the screw terminals of the control boards while the other end was given a crimp end. The thin metal didn't work with my crimping tool so additional compression was needed to hold the wire in place. Green wires were used for the reload button and black wires were used for the trigger. Since these were not polarity specific, no mindfulness was given to how each wire would be used on the hardware.
Crimped wires
