Cut pipes with masking tape markings
The hole locations were marked with a marker and the hole diameter was written on the tape. At the ends where the handle and foregrip were going to be cemented, a knife was used to score the plastic. After the tape is removed, that line can be used to attach the handle and foregrip in line with the tagger. The holes were drilled, some as large as 30mm across and all the tape was removed.
Marking hole locations and center lines
