Adding programming to the Arduino
Adding the program to the Raspberry Pi Zeros should have been an easy task but the wrong OS was downloaded for the computers and I didn't want to learn the finer points of running all the necessary commands through a command prompt. An updated GUI OS will have to be put onto the memory cards.
Running the Raspberry Pi for the first time
Brian McEvoy
