The website will be programmed in python... why? Cause i've never used it before. I want to use this project to learn.
Anyways... thought I might write the web interface in python and save the data in a mysql database. There are probably better options... but I don't know them. I can always port to a better code if required. Let me know if you think tI should use something else...
HTML5? I've no idea...
