Hackaday.io Hackaday.io
Sign up Log in
Arduino + 433Mhz rf communication
What is the best way to communicate with cheap 433Mhz RF transmitter and receiver link kit for Arduino/ARM/MCU?
kevin-cepedaKevin Cepeda
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6.8k views
0 comments
18 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
6.8k
0
18
12
Team (1)
  • kevin-cepedaKevin Cepeda
Join this project's team
hardware
ongoing project
arduino Rf 433Mhz
This project was created on 07/14/2017 and last updated 9 years ago.
Description
RF communication is essential for any type of RC controller. In this project, I've tried to find the best way to send information through a wireless RF Link. I'm willing to receive feedback about my results. I did the project just for fun; however decided to publish it so that other people can see how I did it.
Components
  • 2 × Arduino nano
  • 1 × 433 Mhz rf receiver
  • 1 × 433 Mhz rf transmitter
Project Logs
Collapse
  • 3 potentiometers?
    Kevin Cepeda • 07/15/2017 at 02:30 • 0 comments
    Today I've tried to do the same thing but using 3 potentiometer; it seems to work but the receiver it's not refreshing so the leg RGB doesn't change :( However, it's interesting that when the receiver arduino begins or when restarted, it refreshes. Another thing is that if the antennas are touching each other it works. I think it is not a problem of the transmitter because it works from more than 5 meters away when the receiver is restarted. I might have forgotten something on the receiver code or even i don't know. I'll look for another methods.
    I have some hypothesis about the problem:
    1. The receiver code has a logic mistake.
    2. There is noise between the unit.
    3. This method is not proper.
    Receiver:
    Diagram:
    Code: https://github.com/LukeCepza/433-Mhz-rf/tree/master/Transmisor AM 433Mhz/RF_transmiter_4pot_longchain
    Transmitter:
    Diagram:
    Code: https://github.com/LukeCepza/433-Mhz-rf/tree/master/Transmisor AM 433Mhz/RF_receiver_4pot_longchain
  • Three buttons, one potentiometer
    Kevin Cepeda • 07/14/2017 at 20:52 • 0 comments
    13/07/2017 Communication with text strings.
    First of all, I used the a library called RadioHead for this project: http://www.airspayce.com/mikem/arduino/RadioHead/index.html
    What I did today is to see how a code and hardware behaves. It is pretty much decent and works at distances up to 10 meter (with antenna in both circuits). Still not sure if it is the best way to send data.
    Aside the arduinos and the transmitter/receiver link I've used 4 leds, 3 buttons and one potentiometer. The 3 buttons send a signal to turn on a led respectively, while the potentiometer sends an analog signal to light up or down the left led.
    Receiver:
    Diagram:
    Code: https://github.com/LukeCepza/433-Mhz-rf/tree/master/Transmisor AM 433Mhz/RF_receiver_3_boton_pot
    Transmitter:
    Diagram:
    Code:
    https://github.com/LukeCepza/433-Mhz-rf/tree/master/Transmisor AM 433Mhz/RF_transmiter_3_boton_pot
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
C++ is an efficient language eminently suitable for use in embedded systems but some look for proof of the efficiency. This is the proof.
Project Owner Contributor
Embedding C++
rud-merriamRud Merriam
What do you do with an old fiber-optic Christmas tree? Make it better, of course!
CheerLights Christmas Tree
julie-barrettJulie Barrett
Inexpensive ESP8266 wifi light dimmer.
ryanRyan
Arduino based timer for enlarger used in analog photography
DarkroomRelay
lazarzenitlazar.zenit
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Arduino + 433Mhz rf communication", please tell us the reason.
Send message
Remove Member
