Revision 3.1 - updates
A project log for K.I.T.T. - KNIGHT RIDER badge/brooch
whowhow. whowhow. - formally known as purple rider
davedarkodavedarko • 08/29/2018 at 20:39•4 Comments
I'm nearly through my stock of Rev3 boards and close to another order. There was an issue with the LEDs glowing a bit when the battery was fresh. Two red LEDs in series on a fresh batterie just wasn't enough of a voltage drop. So I sat down and added 4 more 0805 resistors and rewired it completely. Now it should definitely not glow dimly in a "supposed to be off" state.
old version
new version
The SAO connector was moved to the bottom center, but I was too lazy to redo the OSHpark upload - png download cycle again.
deʃhipu wrote 08/30/2018 at 08:00 • point
Love how you squeezed the programmer footprint onto the mirror outline. Have you considered using resistor arrays to lower the parts count?
davedarko wrote 08/30/2018 at 09:08 • point
yes, but I thought those are a bit trickier to solder and I wanted to try out first if 8x 0805 fits at all. I kinda made it work with 2 vias to add the header.
Stephen Ludgate wrote 08/30/2018 at 06:47 • point
I would certainly add in some footprint silkscreen for those resistors, looks confusing at first glance if they are vertical, horizontal etc? Looks great apart from that!
davedarko wrote 08/30/2018 at 07:35 • point
done, thanks :)
