I got this idea while browsing the Lua API for nodemcu (although I don't plan to use Lua).
Besides the normal operational inputs (PIRs, rotary encoders [including switches]), there are no other inputs. I could use some of these things to activate some kind of configuration UI:
- long press of the rotary switch
- double click of the rotary switch
- triple click of the rotary switch (hmm, seeing a pattern)
- basically any combination of long and short presses of the rotary (analogous to Morse code)
- I could also distinguish between the master rotary and a remote rotary
- feedback could be given via the pilot LED or the lights themselves (most likely some series of blinks)
Given this idea, I don't know what I'd actually do with it. Most configuration will be controlled by constants embedded in the code, and updating them is just a matter of downloading a new firmware. I guess this could save me the awkwardness of firmware updates after this stuff is installed.
OTOH, I can also run a web server via the built-in wifi, so maybe this is a pointless idea after all.
