As I put the inner surfaces into the rest of the cube I recognized that the top edge didn't matched perfectly.
First I thought about to just rasp it away, but that would be too much work and I had an better idea:
I think this solution is even better than the first plan, because the space between the green and the grey part is perfect for connectors for the controller and power supply.
