Cloning Port/Confirmed Serial
A project log for Reverse Engineering The Midland WR120-EZ
Attempting to re-band the radio into the ham band as well as develop a tool for backup and restore via serial using the built-in clone port.
signals-everywherekr0sivSignals Everywhere/KR0SIV • 07/20/2017 at 03:24•0 Comments
Hello cloning port, what language do you speak?
First thing is first, what language does the port speak and can I talk to it without too much trouble.
Let's Probe It!
The voltage of the port is actually about 3v, I was using the wrong attenuation when the screenshot was taken. I'm assuming serial communications at this point.
Let's Sniff it!
I don't expect any data on this port unless I'm trying to clone the radio, to do this remove the batteries and power the radio up via the cable while holding the  < and  > buttons. This should give you the following screen.
To Unit / Clone ModePress < > at the same time during boot, press select when ready to send.
I used a 3.5mm break out cable and a UART to intercept communications while peering in with my oscilloscope.
Scope Capture, oh yeah I think we've got serial!
As I expected when the radio is powered we get a steady 3v on the tx pin and when I hit select to start the cloning process we see data as a square wave where the port is being pulled down to near 0v and and going back high to send data.
