Second prototype
A project log for FAR
Fixed-rate Asynchronous Receiver. Extremely simple asynchronous serial input to parallel data output converter.
filipFilip • 08/19/2014 at 16:16•0 Comments
Second prototype does not use the 7400. It is replaced with 2 transistors and the PCB is slightly redesigned.
