Ideally I would use a large diameter brushless motor directly, but doing the sums the brushless motors in my price range just couldn’t provide enough torque, and again, I want to put together an affordable project.
The ghost Minitaur is great, https://www.youtube.com/watch?v=_YrWX9ez3jM, but the motors are just too big and expensive relative to the body.
So a compact gearbox was needed, and a planetary gearbox seemed the ideal solution.
The design was inspired by some of the planetary gearboxes on thingiverse, such as the example at https://www.thingiverse.com/thing:8460
I ran a variety of experiments with planetary gearboxes for the servo. The original gearbox had a ratio of about 40:1, though this was later dropped to 21:1.
First I printed some experimental planetary gear to check they would fit and mesh correctly.
![](https://cdn.hackaday.io/images/1488431500651770974.jpeg)
The two halves of the prototype gear assembly
![The two halves of the prototype gear assembly The two halves of the prototype gear assembly](https://cdn.hackaday.io/images/5265841500652465268.jpeg)
Planetary gears
![](https://cdn.hackaday.io/images/7435811500652810064.jpeg)
The assembled unit.
![](https://cdn.hackaday.io/images/7338371500652556382.jpeg)
