These picture frames were designed to be cut out of a single piece of 12" x 12" material and assembled with wood glue.
![](https://cdn.hackaday.io/images/6512741500581424823.jpg)
A later design revision added a hole in the back of the backplate for optional mounting. Here they are all popped out.
![](https://cdn.hackaday.io/images/1169531500581491711.jpg)
And the final product once assembled:
![](https://cdn.hackaday.io/images/9218561500581601080.jpg)
![](https://cdn.hackaday.io/images/2475061500581600689.jpg)
Using a different material for the rear panel makes the text jump out a bit better when assembled, but once you add a picture it does not make a difference.
