note: I had to fasten the drum sticks to the hand because the grip was not tight enough to hold them with the fingers themselves- so there is definitely still a lot of work to do! :-)
A project log for Robot Building Kit and Development Environment
An open-source robot developing environment that helps inventors build low-cost robots without having to start from scratch.
