Patched
A project log for Numitron Hexadecimal display module
Another hexadecimal display, this one is sans transistor for the extra vintage touch, and uses only Soviet-era parts
yann-guidon-ygdesYann Guidon / YGDES • 04/22/2018 at 02:12•0 Comments
I patched the traces to let the Numitron sit at a suitable angle, close to what I envisioned in the first logs.
I'll have to modify the schematic and PCB layout but fortunately it's not a significant change.
The testing circuit must still be finished, I'm annoyed by the power supply connector. I should use a HE10 header for more than the data.....
