5 modules
A project log for Numitron Hexadecimal display module
Another hexadecimal display, this one is sans transistor for the extra vintage touch, and uses only Soviet-era parts
yann-guidon-ygdesYann Guidon / YGDES • 04/27/2018 at 08:05•0 Comments
Soldering was pretty smooth and the 4 other modules are rather easily assembled. They all worked on first power-up !
So I played with them a bit, to see if the dimensions are good.
I finally decided to solder the relays inside, as previously planned, to keep the overall volume low. Reducing the thickness would have increased the total space used by the display...
The result is not as small as I expected but it's still pretty nice !
Now I have to implement cascading...
