I'll submit anyway
08/19/2014 at 19:59 • 0 commentsI see that at least a few competing projects are missing log entries and/or video links. So I'll just submit and see what happens. I'll likely be disqualified. But maybe my project will haunt some last-minute voter. Muhahaha-ha.
And there goes the chance at a prize
08/19/2014 at 19:52 • 0 commentsWell, damn. Now I notice that a video is mandatory. And it has to be on Youku (is that a Chinese site?) or on You(are being watched by Google-land Security)Tube. I can make a video, sure. But I'm not making a Google account. And it's a bit late to ask someone else to do it, since it's near midnight on the 19th now. Oh well.
Disappointment-induced ranting:
Is it just me, or is HackADay having an unhealthy relationship with Google? These pages seem to work best in Chrome. Chrome translations are often mentioned. And there are a few very conspicuous bugs visible when viewing the IO pages on Firefox. Like, say, the images are cropped a lot in the project view. My PCB photo seems to be... uhh... vibrating? Shaking? Glitching positionally by a few pixels? And if I decrease window width to any less than 800 pixels, then the image thumbnails move and stretch to fill the window. Overall website execution points to a competent engineer, so the only remainingexplanation is that it wasn't tested with all browsers. Perhaps not even with two.
And then happened...
08/19/2014 at 19:37 • 0 commentsThat badly behaving motor control board was not mine, by the way. It was from SeeedStudio. It's probably not a bad one, but it has insufficient suppression. I'm driving at twice the rated voltage of the motors, so a single tantalum was not going to cut it.
So I made the first version of my own design. See the photo with the single half-populated board.
Let me count the errors:
- Half the FETs (a.k.a. the N-side of the H-bridges) are tactically wired to be conductive at startup. Too fast power rise times may bring a momentary short. Yes, all gates have an NPN and a pull-up.
- I put small N-fets to the control lines so that N- and P-FETs could not be turned on at the same time. But since I remembered P-FET gate voltages backwards, the component (if populated) would make sure that both sides got turned on if the N-side was on. Shorted by bad design (potentially. Glad I caught it before wasting components).
- The board turn-on FET, which is supposed to cut power to the whole board (except the MCU that controls it) in case of low battery is active-open. Yes, if the MCU gets brown-out reset, the battery will get it, as the rest of the board starts drawing current from the already (very) empty pack.
- The MCU's timers are less easy to get running the FETs in Sign-Magniture mode than I'd imagined. It looks like I'd have to use 4 of the 6 timer channels to get it running right. No. Just no. That's a waste of perfectly good timer channels.
So, in short, time to redesign again. Next version will use a L298N. Why? Because all the SMD motor driver components need a thermal pad underneath. I'd need a reflow oven to get that right; it's un-inspectable so it needs to reflow perfectly the first time and every time.
Where I'm actually at
08/19/2014 at 19:15 • 0 commentsI started this project about 8 months ago. The first thing I tried was to just slap an arduino on top of a Raspberry Pi and attach a motor driver board. In the photo with the chassis you can see the Arduino-compatible (from Watterott) on top of the RasPi. Fine and dandy, except the motor controller gets jammed to 11, if I increase input voltage over 8 volts and start a motor.
Well, at least my web interface works.
Start
08/19/2014 at 18:40 • 0 commentsOk. Let's see. A prize entry needs documentation. OK. Let's add some photos.
