Seems like this one:
http://dzlsevilgeniuslair.blogspot.dk/2013/07/diy-arduino-based-metal-detector.html
works well, so I will try to build a similar version.
I also think that postioning the metal detectors coil parallel to the ground should be done by a gimbal, but I will have to work it out more exactly..
