Specifications
- 1200 mAh battery
- 1.8" TFT display
- 24-bit DAC
- Dimensions: 92mm x 70mm x 13,5mm
- On/Off switch
- 5 control buttons
- Music player interface
- Index music from
/Music
folder - Sorting by artist, album and tracks
- Control volume
- Queueing
- Shuffling the queue
- Sleep mode (Backlight off)
- Display artist name, album title and track title
- Index music from
Why did I build this?
I had some spare time when I heard Apple was discontinuing their Ipod line. While I was reading about it I remembered that I had most part to build a MP3 player laying around, so I decided to build one.
Project cost
The price of this project is an approximation because I had most of the parts laying around.
Part | Price |
Raspberry Pi zero | € 5,50 |
I2S DAC | € 3,00 |
1.8" TFT display | € 4,00 |
Powerboost 500C | € 17,95 |
1200 mAh battery | € 11,95 |
64GB SD card | € 30,99 |
Other small bits and pieces | € 5,00 |
Total | € 78,39 |
Resources:
Ethernet gadget:
- https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/ethernet-gadget
- https://www.mobileread.com/forums/showthread.php?p=3283986
Audio
- https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=86609
- https://learn.adafruit.com/introducing-the-raspberry-pi-zero/audio-outputs
- https://learn.adafruit.com/adding-basic-audio-ouput-to-raspberry-pi-zero/pi-zero-pwm-audio
- https://support.hifiberry.com/hc/en-us/articles/205377651-Configuring-Linux-4-x-or-higher
