Disc image
There is a new version of the PiPod image available right here, this version has a few improvements:
- Quicker boot time ~30sec thanks to disabling the network
- It's easier to copy music to the device
- The updating of the software is easier
- Using your own Python launcher is made easier
New case files
The next PiPod board will have a thicker PCB to make the device more rigid. The STL files for the case are already available on Thingiverse. These files are named: Top_1.6mm_.stl and Bttom_1.6mm_.stl. There's also a new frame for the inside available this frame is more rigid and fits the 1.6mm and 0.6mm board.
bram
