In more detail the BOLM sensor network has the following capabilities:
- Calculate 3D orientation of the patient
- Calculate the relative, to central node, location of the patient
- Wireless communication to the central node with send-acknowledge and re-send in case of failure
- Patient mobiliity analysis and classification into three states "Idle", "moving" and "fallen"
- Visualization of the measurements, location and states of each patient in real-time
- Open Source design using COTS components.
- Can be extended to provide vitals information of the wearer and adjusted to provide monitoring in other situations were personel telemetry is needed in indoor enviornments.
Both the hardware and software of this project are maintened on GitHub: https://github.com/egk696/BOLM
Chris Gkiokas
Figure 2. Static mobile node measurements at 4 meters from server node.
mrobinson801
panovvv
x3n0x
