Replaced TD4B PCB
Well not much choice, EasyEDA corrupted the PCB after an upgrade (gone wrong again?).
Anyway, this version does not have the RAM add attached or the page register:
The PCB is public so if you want you can get your own version of the PCB (x5) from EasyEDA.
AlanX
agp.cooper
Can you upload or link the pcb? I'd love to build one!
It is fuctionally the same as the last one I built, just redrawing the PCB. It is quite a neat CPU (but very limited). Certainly a good choice for a transistor or relay conversion.
AlanX
looking forward to seeing the results!
