and I am happy with the results. I decided to try 0.2mm (8 mil) traces with a presensitized PCB for the latest and this is how it worked out:
The PCB size is 60x70mm, the IC pads are for a TSSOP-16 with 0.65mm pitch (and my drill bit is worn out...). It is just a "quick-and-dirty" prototype I am going to use for design verification. I will redo the design as a two layer board and send it off to a board house if I later decide to make a small run.
Terje Io
