I've just release a new, improved version of the W1209 Data Logging Thermostat: now the data logger registers the following data:
- relay activation cycles per log interval
- relay duty cycle
- lowest, and highest temperature in the cycle
Used properly, this data can be used to improve the control behavior (heating power), or for getting clues on the effects of heat flow & thermal mass, sensor location, or quality of the insulation:
Check out the README on Github for features, source, and instructions!
Thomas
