Hackaday.io Hackaday.io
Sign up Log in
HOVR: 3D Controller/Scanner
Keyboard, mouse and 3d scanner using kinect style interaction for under $100
dan-duqueDan DuQue
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
1 comments
979 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
  • Official Hackaday Prize Entry
View Gallery
1.1k
1
979
6
Team (1)
  • dan-duqueDan DuQue
Join this project's team
  • youtube
kinect laser 3d mouse 3d keyboard hovr
Related lists
2014 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2014 Hackaday Prize
This project is submitted for
This project was created on 08/20/2014 and last updated 9 years ago.
Description
Utilizing a Bluetooth camera, easily purchased dollar store items and ir leds scavenged from remote controls. I will attempt to merge kinect style control for pc and mobile environments with physical elements designed to ease fatigue associated with using said kinect like devices. As a plus I hope to add in 3d scanning capabilities without having to off load the scan to "the cloud" or other computer/server as well as remove the kinect from the equation unlike Microsoft's current effort to cheaply make a kinect.
Details
Log In/Sign up to comment
Sign up with Github
OR
Rebelj12a wrote 11/10/2014 at 21:09 • point
Here for the 3d scanning... hows it going?
The Wemo Masterswitch is an Electric Imp pushing triggers to the IFTTT Maker Channel using 2 microswitches. Its housed in a 3D printed housi
Project Owner Contributor
IOT Master-switch; IFTTT Hack for IOT Products
jack-chalkleyJack Chalkley
Hacking a cheap R/C car so it can be controlled using hand gestures.
Hand Gesture/Movement Controlled R/C Car
ngerenngeren
3D scan the inside of transparent objects using a camera
Desktop CT and 3D scanner with Arduino
jonathan-bumsteadJonathan Bumstead
In this tutorial, I will show you guys how I created these super simple 3D printed Diwali Diyas
Make Your Own 3D Printed Diwali Diyas at Home
hulkHulk
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "HOVR: 3D Controller/Scanner", please tell us the reason.
Send message
Remove Member
