A LCD panel salvaged from a dead laptop gets turned into a portable external monitor.
Enclosure 3 v41.igesIGES format CAD file exported from Fusion 360iges - 2.06 MB - 08/09/2017 at 23:07 |
Select highlights from the project build blog will be cross-posted here in the future.
In the meantime, the full verbosity is available at this link.
LG monitors give a premium look, and they are easy to use. We have carefully examined all the products from the latest and old collection and got lucky to find the best LG monitor for MacBook Pro featuring an HDMI port for a seamless connection. best lg monitor for macbook pro
this is really amazing project. i am also working on a monitor. here you can check all types of monitors.
For what it's worth, I did something similar and ended up with an laptop panel in a custom-ordered metal picture frame attached to a mic stand with a laser cut set of mounting plates https://blog.lmorchard.com/2017/01/09/diy-monitor-v12/
