Hackaday.io Hackaday.io
Sign up Log in
Portable External Monitor
A LCD panel salvaged from a dead laptop gets turned into a portable external monitor.
rogerRoger
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
4 comments
16 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
2k
4
16
11
Team (1)
  • rogerRoger
Join this project's team
  • Build blog
completed project
hardware
LCD monitor Upcycle reuse salvaged lasercut acrylic
Related lists
Laptop Display Things
All the projects that make use of laptop displays in some way. For more info, see https://hackaday.io/project/179868
This project was created on 08/09/2017 and last updated 8 years ago.
Description
What does one do when gifted with a dead laptop? Here's one answer: salvage its perfectly functional LCD panel and turn it into an external monitor that can fit in a backpack for portability.
Files
Enclosure 3 v41.iges
IGES format CAD file exported from Fusion 360
iges - 2.06 MB - 08/09/2017 at 23:07
Download
Components
  • 1 × LP154W02 1680x1050 LCD display panel salvaged from an old Dell 15" Inspiron laptop
  • 1 × Panel driver circuit board set Searching on LCD panel model number will return Amazon and eBay vendors selling driver boards turning it into a HDMI monitor
  • 1 × Acrylic Sheet, 1.5mm To be laser-cut into front and back pieces of the enclosure.
  • 1 × Acrylic Sheet, 3mm To be laser-cut into the core component spine holding the screen and circuit boards.
  • 1 × Acrylic Sheet, 6mm To be laser-cut into the edge components providing structure to the enclosure.
View all 7 components
Project Logs
Collapse
  • Full build blog
    Roger • 08/09/2017 at 23:23 • 0 comments
    Select highlights from the project build blog will be cross-posted here in the future.
    In the meantime, the full verbosity is available at this link.
View project log
Log In/Sign up to comment
Sign up with Github
OR
jawn6704 wrote 11/02/2022 at 15:54 • point
LG monitors give a premium look, and they are easy to use. We have carefully examined all the products from the latest and old collection and got lucky to find the best LG monitor for MacBook Pro featuring an HDMI port for a seamless connection. best lg monitor for macbook pro
jawn6704 wrote 11/02/2022 at 15:53 • point
jiminjoe209 wrote 04/25/2022 at 17:11 • point
this is really amazing project. i am also working on a monitor. here you can check all types of monitors.
Les Orchard wrote 03/03/2018 at 01:58 • point
For what it's worth, I did something similar and ended up with an laptop panel in a custom-ordered metal picture frame attached to a mic stand with a laser cut set of mounting plates https://blog.lmorchard.com/2017/01/09/diy-monitor-v12/
Will guide you to how to use a Wappsto IoT Cloud and to build your first project with Wappsto.
Project Owner Contributor
Introduction to Wappsto
akarshagarwal98akarshagarwal98
Zeke (10) and I are working together to build a legless Freddy project!
Zeke's animatronics!
muriel-greenMuriel Green
As a Christmas preparation I have buildt "Velleman MK100" Electronic Christmas Tree project.
joe-cornerJoe Corner
Building a Wah Wah petal from first principles.
Wah Wah Boom
dnk17dnk17
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Portable External Monitor", please tell us the reason.
Send message
Remove Member
