While working on a small hardware modification to improve the resolution the obvious improvement hit me: change the display for the ohms so that 200 milliohms reads as 200, not 2.
It was easy but due to the 16 bit maths it required a new word.
V2 of code posted.
Will do. I have built a dual subtractor using a dual opamp which I will write up shortly. This subtracts 10V from the measured voltage ( 2x5v) which will increase my resolution fourfold.
Check out my W1209 thermostat project for another way to add resolution.
