After reading al the info of the Thor and Thor+ robot arm I decided that like this so much that I want to build one myself. The fist part is finished. It is the big case which is going to be mounted to the base.
A project log for Building and improving the Thor+ robot arm
Building a 6-axis robot arm based on the AngelLM's Thor robot and the add-on's and improvements of dannyvandenheuvel.
