Logic Analyzers with Arduino
* Arduino code for 8 pin analyzer
* Due/Pro Micro can be Serial.begin(0);
void setup() {
Serial.begin(0); // <-- Add required speed like 2000000
while (!Serial) ;
Serial.println("Connected");
void loop() {
Serial.write(PIND);
* Run sigrok-cli
sigrok-cli -i /dev/cu.usbmodem411 -I binary -O ascii --continuous
Can add more params like '--config samplerate=9600' <--- set the speed
Dump raw data and import it into PulseView https://sigrok.org/wiki/PulseView
dd if=/dev/cu.usbmodem411 of=./raw bs=1 count=1m
The above can be achieved by counting 0-255
Broken USB, homeless, no more testing... :( Lewisham Council making me sleep rough
Arduino UNO serial @ 2000000Hz
If to go even faster, one could analyse anything up to @100kHz, including I2C
The lab is in storage - can no longer work
Blame DWP, Lewisham Council
Have some extra Entropy on Due http://scruss.com/blog/2014/08/13/screamingly-fast-hwrng-on-arduino-due/
