• Arduino Pro Micro + sigrok-cli + PulseView
    Gintaras Valatka • 09/21/2017 at 16:55 • 0 comments
     * Arduino code for 8 pin analyzer
     * Due/Pro Micro can be Serial.begin(0);
    void setup() {
      Serial.begin(0); // <-- Add required speed like 2000000
      while (!Serial) ;
      Serial.println("Connected");
    void loop() {
      Serial.write(PIND);
     * Run sigrok-cli
    sigrok-cli -i /dev/cu.usbmodem411 -I binary -O ascii --continuous
    Can add more params like '--config samplerate=9600' <--- set the speed
    Dump raw data and import it into PulseView https://sigrok.org/wiki/PulseView
    dd if=/dev/cu.usbmodem411 of=./raw bs=1 count=1m
    The above can be achieved by counting 0-255
    Broken USB, homeless, no more testing... :( Lewisham Council making me sleep rough
  • Arduino Uno - faster than you can blink, Serial.begin(2000000);
    Gintaras Valatka • 08/14/2017 at 23:07 • 0 comments
    Arduino UNO serial @ 2000000Hz
    If to go even faster, one could analyse anything up to @100kHz, including I2C
    The lab is in storage - can no longer work
    Blame DWP, Lewisham Council
