#OktoberfestOfThings
Internet-connected Masskrug
An open project started by @gy4nt and @tamberg. Investigating ways to connect beer to the Internet. Field test under the hardest possible conditions, at the original Oktoberfest. More at http://oktoberfestofthings.tumblr.com/
tamberg wrote 08/15/2014 at 14:16 • point
Don't miss the #OktoberfestOfThings 2014 hack day in Munich: http://www.meetup.com/IoTMunich/events/197954622/
Nippey wrote 04/04/2014 at 05:29 • point
Drinking... for *science*! :D
Prost!
Mike Szczys wrote 03/08/2014 at 18:10 • point
I shudder when I hear "Internet of Things", but I can really get behind a movement called "Oktoberfest of Things".
It looks like you have have detection for how much beer is in the stein, and when the stein is not on the coaster. You should be able to use predictive algorithms to know when the glass will be empty. With BTLE you can chirp back to the bartender so that a replacement will arrive when needed. This is the malt-beverage version of Just-in-Time supply chains.
tamberg wrote 03/09/2014 at 00:41 • point
Cheers!
Moritz Walter wrote 03/03/2014 at 12:19 • point
Finally someone invents the smart beer!
Suggesting to add NFC and breathalyzer for a touching glasses triggered tweeting of blood alcohol levels!
