(07/21) Successfully built and tested a working relay based outlet module. This module uses a HC05 bluetooth module to communicate to the central hub.
A project log for Low Cost Home Automation
A home automation solution that utilizes a Raspberry Pi server, 433MHz radios, and an Android app.
